Help, SUPER HIGH IDLE.
Old Mar 13, 2012 | 06:41 PM
Originally Posted by 2strokezilla
It can rev up when you are running out of fuel. Mine has done this before I just make sure tank is full. Might be good idea to spray carb cleaner all aound the carb, boot, reeds and cylinder base and see if it raises the rpm.
Have had dirt bikes and water craft do this,especially scary on the water craft just testing out of water(can only run about 20 seconds at a time out of water!) If they happen to get too hot they will rev to the moon and you have to choke em down or block the carb with your hands until they die. Doesn't matter what you have on premix ratio,if the carb runs low on fuel while it's running,then the cylinder has less fuel and will run lean and rev! Do as 2strokezilla said by spraying carb cleaner around the carb, boots,etc. If it's sucking air you can tell by the engine speed,PLUS you can smell the carb cleaner through the exhaust as it burns and will burn your eyes from the fumes! OPT
Old Mar 15, 2012 | 11:13 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Yup the guys are right. When its running out of gas, instead of backfiring like a 4-stroke, they tend to rev really high. Had an old blaster that did it every time. Switch to reserve and problem SHOULD go away.
Old Mar 16, 2012 | 08:33 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Thats how I know my grandson's blaster is about to run out of fuel. The idle get real high. Just the nature of a 2 stroke.
Old Mar 19, 2012 | 02:15 PM
submakr's Avatar
You should be able to replicate the problem by simply turning off the petcock. It should rev high then shutdown.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
