Brake Light help
Old Mar 21, 2012 | 07:42 AM
Scooter250's Avatar
Default Brake Light help
i have 2004 ozark 250 when i use the brakes the brake light dont get brighter it just stays the same, does this atv have a brake light or does it just have a running light ??? is that just the way it should be or is there a problem thanks for any help !!!
Old Mar 21, 2012 | 02:20 PM
Jaster94's Avatar
two fold function. brake light and running light. check the bulb. check the brake switch.
Old Mar 21, 2012 | 06:18 PM
Scooter250's Avatar
Thanks i do that !!
Old Mar 22, 2012 | 01:34 PM
Jaster94's Avatar
up at the handlebar brake lever, squeeze the handle. do you hear a "tink"? if so, your switch is being activated. if a new bulb doesn't work, you'll need to check the wiring at the switch to the tail light assembly.
Old Mar 22, 2012 | 03:40 PM
Scooter250's Avatar
Perfect !!!!! Thanks i did hear it making the noise and found the switch to be bad thanks for the help !!!!
Old Mar 27, 2012 | 09:13 PM
Jaster94's Avatar
glad you got it running. now go have some fun!
Old Apr 1, 2012 | 01:10 PM
Scooter250's Avatar
here we go again the bulb just stays on light you have the brake on worked ok for a while now back on bright again if i unplug the switch it stays on just like the brakes are on
Cummins Driver
Sep 11, 2019 01:22 PM
sweaver
11
Aug 18, 2015 03:47 PM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
