1984 LT50 Motor Issues
Old May 4, 2012 | 09:22 AM
KS-GLOCK's Avatar
Default 1984 LT50 Motor Issues
I have read all the post I can find on the LT 50 and still need some help. I have a 1983 or 1984 LT 50. I have read compression in the cyclinder and it comes out to 50psi. I obvisiously need to have it bored. My question is, do I go with the .20 or .40 over? Is there a better option in this case? I'm getting it to just putt around in and have fun with. The quad is new to me and it has been derestricted and ran great before but along the way it lost compression. They honed it out and said it needed to be bored out.
Second thing, I'm guessing it will be easy to take apart and put back together but I'm not sure because I have never done it. Any tips on this? Is there anything in there I should fix while I'm at it? I need to replace the piston, rings, and gaskets on the motor. Anything else you can think of while I'm in there? The carb has been replaced with a newer better one from what I'm told. The previous owner also got rid of the oil tank and went to premix. Other than that, it's stock. Any pictures would be great to if you have some involving tear down. I'm new to the 2 stroke side of engines and think it would be a fun little project. Thanks in advance for the help.
Old May 5, 2012 | 08:59 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
You will also need a new piston pin and pin bearing.
You get the next size up on the piston. You'll need to see what's size is in it.
2 strokes are easy. No valves or timing to mess up.
I'm sure you can handle it.
ghost civic
Jan 15, 2020 07:43 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
timster911
Jul 13, 2015 01:57 PM
