86 quadracer lt250r
Old Jul 8, 2012 | 10:30 AM
VOXGM's Avatar
Default 86 quadracer lt250r
Hey guys. I have an 86 Suzuki lt250r quad racer and I need a pod filter. The guy that owned it before me rebuilt the motor but ran it with no air filter. First off it is a keihin carb but it seems it doesn't exist at all. The numbers are PH24abhye. I have no clue what size carb this is and what kind of pod to get. I also wanna know if I should run sea foam through it to clean any junk that was sucked up.
Old Jul 8, 2012 | 11:28 AM
Scooter86's Avatar
Knows Old ATV Questions!
Skip the Sea Foam. It isn't going to fix any damage done to the piston, rings, or jug that may have been incurred by running sans filter. I would pull the float bowl and manually clean it and any passages to eliminate contaminates. While you are at it, clean whatever is still intact of the intake tract as well. The Keihin is likely aftermarket. If you are just looking to run the filter straight off the carb all you should need is the OD measurement from the filter side.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
chrisjack
Aug 21, 1999 04:52 PM
