86 lt250r occasional high idle
Hey guys, I just got my lt running last night and I had the Carb dialed in pretty well but it was a little sputtery at full throttle so I went down one size on the main and it didn't change at all but then after I put in the smaller main it would occassionally start to lean out at idle but all it did was go up a little in rpms then come right back down then after another 30 seconds or so it would do that again, I tried messing with the air mixture screw and it didn't Change, so then I changed back to the main I had in it at first but its still doing it. I sprayed wd-40 around the jug gasket and nothing changed. Any suggestions why it would do this??
O I forgot to mention that it was idling fine with the smaller main jet until it started running out of gas when it died I turned reserve on and was waiting for it to fill the bowl back up and I walked away and when I came back the bowl was overflowing so i shut the gas off then went to start it and it was flooded and then after about 10 minutes it started and its only been idling funny since then
house1
Aug 9, 2015 10:49 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
