Suzuki Eiger 400
Old Sep 10, 2012 | 05:52 AM
kkiser's Avatar
Default Suzuki Eiger 400
I am in need of the electrical diagram or pdf file for My Suzuki Eiger 400. I have changed spark plug and coil but I still dont have any spark. I havent got into the case yet and need a wiring diagram to check out the harness in case I have a broken wire or something. I have checked all the fuses they are all good and I have checked the parking brake switch. If someone has the wiring diagram I sure would appreciate it
Old Sep 10, 2012 | 09:13 PM
RonV's Avatar
You can get a service manual CD on Ebay for about $10 shipped.
Old Sep 16, 2012 | 08:17 AM
kkiser's Avatar
thanks found problem now I have another problem need to find procedure to take off rotor. Mechanic used the tool but mushroomed my shaft. he didnt get it off and I tried and I couldnt get it off . I even heated and tried still wouldnt come off . Wondering if he or I did something wrong. Also I dont know if you have to take the allen head bolts out or not.
Old Sep 16, 2012 | 10:54 AM
papa hogg scoot's Avatar
Loved
Community Favorite
IMO I would get the correct tool to remove flywheel before tear up an 300 buck flywheel and 400 buck crankshaft.....The tool pulls from the edge if flwheel by the threads...Shouldnt have to heat up anything with the correct tool...But sometime it can be tuff with correct tool but will finally come off.....
Old Sep 16, 2012 | 10:55 AM
Loved
Community Favorite
Is your flywheel bad? is this why you are trying to get it off?
Old Sep 16, 2012 | 11:04 AM
kkiser's Avatar
yes the rotor magnets came off and I had a parts atv with good one and had a suzuki mechanic try to get the good one off and I think he used a hammer to kind of help the M50 tool and he broke the magnets on it , then he tried to get the bad one off my atv and he couldnt pull it off either Do you know if I have to pull the allen head bolts out before pulling> I think it just hold the plate for the flywheel gear
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
