1998 suzuki ltf 500 has no top end
Old Oct 2, 2012 | 05:02 PM
K9/76's Avatar
Default 1998 suzuki ltf 500 has no top end
I have a 1998 suzuki ltf500f 4x4. It runs fine, starts fine and idles fine. The problem i am having is that it has no rpm increase after 1/2 throttle. I rebuilt the carb with a kit. I am a decent mechanic, i have been working on bikes and atvs for 20 years or so. The throttle on this atv is a diaphram operated slide. I dont know enough about this type to trouble shoot. Can anyone point me in the right direction? Thanks
Old Oct 2, 2012 | 05:20 PM
roadiestar's Avatar
I would take the carb off and start all over again. Make sure you have a every little the hole cleaned out. Check for vacuum leaks around the carb .
Thats were I would start and go from there.
Old Oct 2, 2012 | 05:37 PM
K9/76's Avatar
yea im gonna go over it again. The only thingi am unfamiliar with is the diaphram operated throttle. everything else inside the carb is new except the float itself. thanks
Old Oct 2, 2012 | 05:47 PM
roadiestar's Avatar
Do you have it snorkeled? Is it stock or did you do anything to it ?
Old Oct 2, 2012 | 09:02 PM
K9/76's Avatar
Smile
i just spent the last 2 hours on the carb. I found the problem............when i put the cover on the diaphram the diaphram came out of the groove a little bit on one side. It wasnt sealing on full vacuum so no top end. I just took it out and man does it fly. all kinds of speed and power. MY STUPID MISTAKE. Thanks for the help. TP
Old Oct 3, 2012 | 04:41 AM
roadiestar's Avatar
Old Apr 15, 2014 | 06:32 AM
marshall7820's Avatar
Default LTF 500F Problems
I have a 1998 suzuki ltf500f 4x4. It runs fine, starts fine and idles fine. The problem i am having is that it has no rpm increase after 1/2 throttle..The throttle on this atv is a diaphram operated slide. After 1/2 throttle it sounds like the rev limiter kicks in
please help
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
