LT80 with no off-the-line power
Old Nov 27, 2012 | 08:51 PM
Onespeed24's Avatar
Default LT80 with no off-the-line power
Hey all, I just rolled out my sons LT80 to get ready to go to the desert and it has an issue I can't quite figure out.
Background:
It has motor and clutch work done by "LT80" and has run great in the past.
This quad used to peel out and would damn near do a wheelie when getting on the gas from a standing start... and now...
Symptoms:
Motor starts and idles fine (new gas and oil, clean filter).
When you hit the throttle it revs fine, but no power.
I had my son take a couple of trips up and down the road and it will eventually get going, and once the revs get up it almost seems like it kicks into a second gear, then takes off like a scolded ape.
If its on an incline it will barely get going, but it does get moving eventually.
Bottom line: It has power once it gets going, just no power to get off the line. No bottom end torque, but does have top end speed once it gets moving.
Does this sound like a motor/compression problem or a clutch problem?
I sent "LT80" an email but hopefully can get some suggestions here as well.
Old Nov 28, 2012 | 12:07 AM
LT80's Avatar
LT80 Expert
It could be either but........You need to service the clutchs for a trip to the dunes anyways...right??.
Get in there and see what's going on.
Old Jan 15, 2013 | 11:25 AM
allmotor408's Avatar
One Speed, (I know this is an old post) but did you ever find you problem?
Did it just need a clutch adjustment?
Old Jan 15, 2013 | 05:27 PM
LT80's Avatar
LT80 Expert
Same reply... get in there and see what's going on (maintenance).
Your going to find that in the front clutch, the grease has got hard and stopperd roller travel. All the rollers will be bad and possibly the variator and roller plate.
Or maybe a stuck rear clutch.
My money is on the front.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
