Ltz400 rear brake issue....
Old Dec 15, 2012 | 10:01 PM
fastidiouspa's Avatar
Default Ltz400 rear brake issue....
Hey guys im new to this site but i thought i'd give it a shot... i've been trying to fix my rear brake on my 2003 ltz400 for the past 2 weeks and i haven't had any luck with it... i bought the rebuilt kit for my master cylinder and installed that.. i bought new rubber seals for the caliper drum and replaced them... i also took the caliper apart completely and cleaned it fully, the drum now moves freely with no problem.. i also took the brake lines and blew air through them to make sure they weren't clogged.. after i put everything back the issue im having is that i try to bleed and bleed the brakes and never get any pressure at the caliper.. i have a feeling the my master cylinder doesnt send fluid and pressure but like i said i rebuilt it so everything is new in it.. can anyone please help me resolve this issue.. thanks...
Old Dec 16, 2012 | 07:34 AM
dsldug77's Avatar
Most important thing to remember is bleed the brakes closest to master cylinder first then work your way out to the farthest. Also I have rigged up a rubber gasketed metal plate with an air chuck attached. Crack the bleeder screws and add just a LITTLE air pressure to start the fluid down the lines. Good luck
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
