07 eiger 400 automatic spark problem
Old Feb 18, 2013 | 08:40 PM
Chad Payne's Avatar
Default 07 eiger 400 automatic spark problem
Can any one give advice was turning sharp and atv died and won't start just cranks pulled sparkplug and when I crank it not seeing any spark can any one help even held finger over plug wire and cranked I know on a car if u are getting spark from coil it will shock you so I am wondering if coil is bad want another opinion on this
Thanks
Chad
Old Feb 19, 2013 | 02:22 PM
Normex's Avatar
A few possibilities here and as mentioned the coil but I would check fuses and check closely at the wires at the steering column since you mentionned after a sharp turn.
But my vote is the fuses and coil initially.
Good Luck
Norm
Old Feb 19, 2013 | 05:26 PM
Chad Payne's Avatar
I did check fuses today and also bought new spark plug just to eliminate that a buddy told me today maybe the Cdi box will probably go over there this weekend and put test light on coil to see if getting power to it
Thanks for the info
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
ranvette
Jul 4, 2015 06:13 PM
D-Hagz
Jul 4, 2015 02:19 AM
