Chain and Sprocket upgrades!
Old Mar 19, 2013 | 01:35 PM
JustRandy's Avatar
I would try to find the smallest rear sprocket I could and decide on the front based off what I could find for the rear. I run 12/36 which is the same ratio as 13/39 but puts more power to the ground. With 18 inch tires, you might be able to run 13/36, but the 13 will suck up some power. Then again, its pretty easy to turn 18 inch tires so it may even out.
Old Mar 19, 2013 | 01:51 PM
trober_603's Avatar
Im running Kenda AT22x11-9's and its got the stock 11/41. I think that ratio plus the big lugy tires makes it slow lol i want a set of low pros and 13/39's or something like that!
Old Mar 19, 2013 | 01:54 PM
JustRandy's Avatar
Yeah... 22 inch tires is like riding with the brakes on. I have 20s and wish I had gone with 18s. Actually, I might scrap the perfectly good 20s and get 18s lol
Old Mar 19, 2013 | 01:57 PM
trober_603's Avatar
ya i didnt buy these last pair lol so they really werent what i wanted but heck i dont grip about free tires expecially with how much they cost lol so if i were to get 18s a good ratio would be 13/39? Good power and speed?
Old Mar 19, 2013 | 02:03 PM
  #15
JustRandy's Avatar
Power would be good, but you will wish you had a 6th gear. I always do.
Old Mar 19, 2013 | 02:05 PM
  #16
Valder's Avatar
Thanks, I'll give that a try. The ITP wheels I got were 4/115 so I picked up a set of Banshee hubs cheap and they fit perfectly on the axle of the 250s.
  #17
trober_603's Avatar
ya i do now lol reallyy low geared.. so you have 20's with 13/39's
Old Mar 19, 2013 | 02:13 PM
  #18
JustRandy's Avatar
Really? Banshee hubs fit the stock axle? Need to make note of that.
Yeah, basically. I have 20s with 12/36, which is the same ratio as 13/39... its a 1/3 ratio. 11/33, 12/36, 13/39 are all 1/3 ratios
Old Mar 19, 2013 | 02:19 PM
  #19
Valder's Avatar
I didn't tighten them down since my quad is all in pieces waiting to get powdered, but it looks like they will snug up on the stock axle for a perfect fit. There are some nice extended hubs I might eventually get to widen the back end up a bit.
Old Mar 19, 2013 | 02:22 PM
  #20
JustRandy's Avatar
As long as there is no play in the splines or the nut will back off and strip the splines.
