2007 King Quad Battery Drain Solved?
Old May 13, 2013 | 11:49 AM
c-ne-elk's Avatar
Default 2007 King Quad Battery Drain Solved?
A newbe here - I searched and found some old topics regarding the '07 KQ battery drain and some solutions but never really saw that anyone fixed it. One of the final posts that I saw discussed taking the key out solved the issue. A new ECU was another possible fix and yet another possible fix was the grounding issue. But no one came back after discussing it (that I could find other than one person) and said "this fixed it"
I just purchased a 07 KQ with 424 miles on it from a friend that was his wife's quad that she hardly rode. He has the identical quad and both quads have had the battery draining issue since he purchased them new.
My question: Is there someone out there that had this problem and fixed it?
Thanks in advance!
Old May 13, 2013 | 04:20 PM
papahouse's Avatar
Mine did the same, I disconnected the winch and it stopped.
Old May 13, 2013 | 08:52 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Nyroc's ATV info website
Old May 13, 2013 | 08:53 PM
Loved
Community Favorite
Read this web page this is what I have been doing an have good luck with it,,,,
Old May 14, 2013 | 08:08 AM
c-ne-elk's Avatar
Thanks papa hogg. I had seen that but had not seen that anyone had any luck with it. Mine is obviously past the 36 months old to get it for free so did not want to spend the $325 on a new ECU if it did not work or at least help.
Old May 14, 2013 | 08:20 AM
TLC's Avatar
TLC
Thumbs up
Originally Posted by papa hogg scoot
I like that site.
Old May 14, 2013 | 09:06 AM
c-ne-elk's Avatar
Yup, it's a wealth of information!
Old Jun 9, 2013 | 09:45 AM
bert63's Avatar
Default 700 efi battery issues
i had the same problem, and tried everything.nothing worked, until i read a post on here i think it was by king ding. re; the factory using to small of guage wire from the regulator to the battery,i did that update and have not had a problem since with the battery going on 2 years. but it still will stall at idle if the fan kicks on or i try to use my lawn sprayer at idle
i will try to find the post with the update for ya
Old Jun 9, 2013 | 10:32 AM
bert63's Avatar
Default batt. issues
search king quad 700 battery issues. the wiring mod is in that discussion, that mod. solved my batt. issues. i would recomend it. check your voltage before and after the mod. you may be supprised.
hope this helps
bert
two stroke toyz racing.com
moneyman01
Jul 11, 2015 08:50 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
Wolverine16
May 18, 2000 09:18 AM
ferret3
Aug 4, 1999 08:23 PM
