1989 Suzuki lt250s leaking from overflow tube
Old Jul 12, 2013 | 11:30 AM
collinsjs's Avatar
Default 1989 Suzuki lt250s leaking from overflow tube
My overflow tube on the 1989 suzuki lt250s keeps pouring fuel out of the end. is it supposed to leak some or at all. I have adjusted the float but any time i turn the fuel on and the bowl fills up thats when the fuel starts pouring out of the overflow tube. can anyone help
Old Jul 12, 2013 | 08:55 PM
mla2ofus's Avatar
You either have a peice of crud stuck between the needle and seat or it's time to replace them. Might also check to see how high the float "floats" in gas.
Mike
Old Jul 14, 2013 | 01:19 PM
collinsjs's Avatar
Suppose everything works fine. Is the overflow tube supposed to leak fuel from the end if it is used
Mike[/QUOTE]
Old Jul 14, 2013 | 10:11 PM
mla2ofus's Avatar
The reason it's called an "overflow" tube is because the float chamber is too full. You need to find out why.
Mike
Old Jul 15, 2013 | 06:45 AM
collinsjs's Avatar
I undrstand that. I adjusted the float and now it doesn't go into the overflow tube. I am trying to figure out if it needs replaced. So assuming fuel does go in there again, is it supposed to hold it in or let it leak out
wendal
Sep 15, 2015 01:50 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 08:03 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Sep 1, 2015 11:59 PM
