2006 Eiger Backfiring
Old Aug 20, 2013 | 02:57 PM
lovemysusikieiger's Avatar
Default 2006 Eiger Backfiring
I recently had to purchase a new Air Cleaner box for my Eiger...Trailer came off hauling hay and ran under and broke the box. Had to buy entire assembly..so I put the new Air Cleaner on and now the bike runs rough and backfires. I have cleaned the air cleaner thinking it had too much oil on it. I ran this bike for about a month with hole in air box. Could I have got dirt into motor or maybe I need to re-jet the carb? please any help Its archery season and back fire scares the deer and elk away......thanks
Old Aug 28, 2013 | 10:25 AM
Back40's Avatar
Flush the float bowl to make sure it does not contain any debris. Better yet disassemble and clean the carb and install an inline fuel filter
Service Manual Table of Contents
Lots of Eiger owners have re-jetted since the factory jetting is own the lean side.
Lots of older threads on this issue.
Old Aug 28, 2013 | 10:48 AM
the_revern's Avatar
If you upgraded ur airbox you will need to rejet. Or turn the air fuel screw in or out till it stops popping. Sounds like you too lean
ReconBayou
Oct 31, 2022 05:37 PM
akguy31
Aug 31, 2019 04:34 AM
fordfaithful21
Dec 7, 2015 05:52 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
