2x4 modified to one wheel drive?
Old Nov 3, 2013 | 11:11 PM
damone's Avatar
Default 2x4 modified to one wheel drive?
I have a LT250 quad motor/tranny in golf cart.
Looking to modified rear axel to be one wheel drive. The locked dif pushes cart to almost tip especially when turning on pavement.
Thinking about removing 1/2 the axel to make a 1x4?
Thoughts?
Old Nov 4, 2013 | 11:32 AM
sr.ruedas's Avatar
You can do that and your on-pavement performance will be much improved. Off
pavement, not so much. Never off pavement, then go for it.
Golf carts, electric or gas, often have rear diffs already. Can't you use the original
axle and rear end with your Suzy motor?
There is only one ATV I have found that comes with a rear differential: the 86-04
Kawasaki Bayou 300 4x2. They are uniquely suited to pavement use, and come
with a lever to lock it for off-road use.
You can also buy a lawn tractor rear axle with diff pretty cheap.
Old Nov 4, 2013 | 09:02 PM
damone's Avatar
The quad axel appears to have a differential just like a mini version of a car or truck.
Not sure how to modify now. Tried to get drivers side axel off, but couldn't get axel nut off or the axel housing from the dif to the hub. Got bolts out, but it would budge off the dif.
Mostly offroad very little pavement.
Old Nov 5, 2013 | 07:22 AM
TLC's Avatar
TLC
Is it this atv?
Here is a shaft drive model with rear diff. Its a Yamaha but should be close.
Old Nov 5, 2013 | 08:49 AM
damone's Avatar
Looks like 2nd video. I geuss I was working from wrong end. But in the end I couldn't have done anything anyway. Staright axel with no differential. Cant make it 1x4 cuz the wheel is suspended by the axel, therefore it cant be removed.
Thanks for the vid.
Old Nov 5, 2013 | 12:37 PM
sr.ruedas's Avatar
No differential on the LT250. A "final drive" or "rear end", yes, but
these are "solid axle" or "live axle" vehicles. A differential has spider
gears so that the 2 rear wheels can turn at different rates. That
also means you would have 2 half-shafts, and you don't.
No way to go one-wheel-drive with the LT250 axle-supported wheels.
Thought you might use the golf cart suspension and diff.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
metal249
Jul 28, 2015 09:35 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
