Runability/Power issues with Dynojet jet kit - 2005 Vinson
Old May 1, 2016 | 08:44 PM
bluffcountrywarrior's Avatar
Originally Posted by Fasteratv
More than likely the diaphragm does not have a hole it....you would feel it any time you nailed the throttle...it would pop and probably backfire. The main jet controls the top end speed. With the stock main ( and jet needle ) now installed...you should have the same performance you had before installing the Dynojet kit. Have you done anything else...like intalled larger tires or anything? Added any weight of any kind? Good charge on the battery?
I do have one size larger tires on all the way around, as well did some minor clutching changes, but this was all done prior to this current issue, and it ran great. The one thing that I will do is put the trickle charger on the battery to ensure it has a full charge. Other than that, I am at a loss with what it could be. After charging the battery, and if that does not do it, I will go through it again and see if I may have missed something. Thanks for all of your insight...much appreciated!
Old May 1, 2016 | 09:10 PM
Fasteratv's Avatar
Good luck with it. Keep us informed on what you find...hope it's something simple......
Old Jun 5, 2016 | 06:23 PM
Problem solved...ended up being the diaphragm was not full seated, so got that taken care of and runs great with the jet kit in it. Thanks for all the help; much appreciated!
Old Jun 6, 2016 | 11:09 AM
Fasteratv's Avatar
Glad you got it figured out. Ride....and have some fun!
Old Jun 6, 2016 | 12:41 PM
  #15
hydrex's Avatar
Good news! Sorry I didn't think of that. My AC was very sensitive to getting the right c-clip setting, btw (same motor). When I finally got the wideband, discovered it was pig rich, but ran good.
Old Jun 6, 2016 | 03:33 PM
  #16
Fasteratv's Avatar
^^^ wouldn't be concerned...in was brought up in three different posts in this thread....just took him a couple of trys to get it seated....
Whitelx1
Feb 29, 2016 12:54 PM
shaddysfx
Feb 28, 2016 08:49 AM
Kymco 450i
Feb 11, 2016 09:56 PM
Apache77
Feb 11, 2016 01:19 PM
amalota
Feb 5, 2016 01:45 PM
