LT80/KFX80 Bogs down when throttle is 'mashed'
I need some help with an issue, i purchased a 2003 KFX80 used and it seemed to run fine when i got it. tested it with me on it and plenty of power.
When i took it home i noticed the idle was set almost to the max! so much that the bike was moving ahead even with the brakes on. So i dialed it down for my kids , now it idles without moving but have noticed that maybe ever since there is no low end torque? If you gently push throttle eventually it hits its 'power band' and boom all the power in the world but if you push it down too fast its just bogs down and almost drowns.. so then my kid is stuck in the mud or trying to climb a decent hill, unless she gets a running start i get no power at all.
you guys think its just the carb that needs to be cleaned out? Could that be why the old owner had the idle set all the way to the max? to compensate for the issue i seem to be having?
Any help is greatly appreciated
when it first started after reconnecting everything it seemed a little better? but then after 3-5 mins and my wife riding on it, same symptoms. LOW end is gone, no power whatsoever, but if i can get it revving high enough and keep it med high rpm its got tons of power.
Could i have issue with the float and the valve not shutting off the gas properly? flooding the carb bowl? I know that if i do not turn off the tank valve when i shut it down for the day it will be flooded the next. I have an ON/OFF/RES shut off valve installed.
Also LT80 i took off that rubber piece that was over the jets as I saw in another post you had said it was useless? see pics, also it would not fit back on properly.
Imgur: The most awesome images on the Internet
So any other ideas guys? I figure its not normal for the bike to bog out when starting from a stand still at the bottom of a small hill
Also how much power should this have on low end anyways? I'm curious, as it is i can hold it back while straddling it and punching the throttle.
But it can haul my *** up a steep hill if i take a run at it. never really had low end 2 strokes so not sure on what to expect
Could this all be a clutch issue?
Yes it could. The grease can get hard and limit roller travel. You should service the clutchs regardless.
I think you should expect more out of it. You should be able to wheelie with a lil pull on the bars.
After clutchs, then I'm back to compression or plugged pipe.
Feel how much exhaust is coming out of the pipe. If in doubt, pull the pipe away from the cylinder and try it.
Also i took off the pullstart cover(as i have none) to take a quick peek looks real clean in there but should the belt be riding high on the front clutch like it is in the pics i have attached? best i could do sorry
http://imgur.com/a/MxNlV
