King quad problems.. Anyone ?
Old Apr 23, 2017 | 04:47 PM
KQ2492's Avatar
Originally Posted by merryman
The starter running is a faulty solenoid if it continues to run with ignition turned off. However a faulty battery can make the solenoid do this, so check the battery voltage is over 12v with nothing switched on. If turning ignition off stops the starter, you have a faulty starter button.
Thank you for clearing that up for me
It does it with the key turned off only way to stop it is by disconnecting battery
Another problem I have is the start button only works sometimes... But while the ATV is running if I press the start button I can hear the starter motor spin every time I press it then I shut off engine press start button it starts to turn then stoppes ? Is this a combo of bad silinoid and battery ?
Old Apr 23, 2017 | 04:49 PM
KQ2492's Avatar
Forgot to mention battery is usally between 12.4-12.9 vs never under 12
