85 Lt230s vm26ss carb help
I recently acquired a 1985 Suzuki lt230s. My problem with the carb for the 230s is it looks like I will need to replace it mainly because I can not get it apart to rebuild it. The guy I bought it from lived on the water and the salt in the air has seized it. Now here is my problem what do I replace it with. I can not find a vm26ss carb anywhere. Does anyone have a new part number or know what other carbs would work or have a good used one they want to part with. Any help would be greatly appreciated
You might look at some used or new carbs on ebay.suzuki lt230 carburetor | eBay Cheaper than the 250 bucks for a new one at Partzilla.
Check out DG performance, they still have an aftermarket carb kit for the 230.
http://dgperformance.com/motorcycle-exhaust.php?pyID=314
other than that eBay is your best bet, unless you want to get a 28mm flat slide and mess with jetting. Check out the big LT230s help thread.
