Thin oil ??
Old May 2, 2017 | 07:16 AM
oldhoss's Avatar
Default Thin oil ??
Ok , got my 2004 eiger up and running good but i noticed when i first got and was tearing into the engine the oil seemed kinda thin and seemed to smell heavy of gas. It had to much in there to begin with so i made that right, has anyone else noticed this to be true?
Old May 2, 2017 | 07:37 AM
hydrex's Avatar
The best thing that you can do, when you change your oil, send a sample to Blackstone Labs. If you have gas in the oil, I'd first check the float height in the carb. If you have a fuel shut off, shut off the gas when you trailer it. Here is what a report looks like. My old Arctic Cat 500 , same motor as yours, btw. I sold it, it now has over 9,000 miles. Switched to Shell Rotella T6, you can see the improvement over Mobil one and the first test was conventional, non synthetic.
File Type: pdf
Old May 2, 2017 | 08:11 AM
LT80's Avatar
LT80 Expert
Ethanol messing the float needle up allowing fuel in. That's my guess.
Old May 2, 2017 | 11:59 AM
oldhoss's Avatar
Default thin oil ??
I'll for sure check the things you guys have mentioned. Are you saying that you think a synthetic oil will be better?
Old May 2, 2017 | 12:20 PM
oldhoss's Avatar
Also merryman says he has had a dealer mechanic put 4 qts of oil in his and it showed high and he pumped some of it back out... mine was over filled as well and i only put back to the top of the dip stick hash marks but i've noticed a bubbling or slight boiling sound coming from the case after running the bike a little bit... so im wondering if the eiger should have 4 qts of oil which will put the level way over the hash marks? Anyone know for sure?
Old May 3, 2017 | 02:53 AM
"Also merryman says he has had a dealer mechanic put 4 qts of oil in his and it showed high and he pumped some of it back out" Oh no I haven't!
The Eiger doesn't have an overflow for the float chamber. Like LT80 wrote, if the float needle sticks, fuel floods the sump and airbox if the tap has been left on prime. The oil needs changing, airbox emptying and make sure the tap is on RUN.
Old May 3, 2017 | 07:26 AM
oldhoss's Avatar
Default thin oil
I'm sorry merryman, i thought you had posted that in another thread...
