LT80 will not start and turns slowly
Old May 29, 2017 | 12:51 PM
rowdog_14's Avatar
Default LT80 will not start and turns slowly
Hello,
I just a 99 LT80 and it had been sitting for a while because the gas was horrible. It would not start nor would gas come out of the tank. I drained the tank and cleaned the gunk out of the valve. Fuel started coming from the tank and I was able to start it. It was running great, some white smoke coming out and idling good. Do not know if it should smoke?? I even let my kid ride it twice and I jumped on it a few times. Well, I went to put it up and it stopped and would not start. I tried to start it and it spun fast and never did fire and then it start turning slow and finally clicking. I found the breaker, and it trips again and the relay wires get hot. Here are the things I have tried
1. Thought it was flooded so I turned it on its tail to try and drain
2. New plug
3. checked the pump to see if oil was coming out at the carb from the oil under the seat
4. tried starting straight from the starter(still turns kinda slow and the negative wire get hot on the battery)
5. tried starting fluid(nothing)
6. I opened the carb but all looked good, I probably could completely break it down
Looks like the plug is getting spark. I think the starter is shot and needs to be replaced so I am going to buy a pull starter for now.
I have read everything on different forums and have come down to either
1. Low compression which I have not tested
2. Crank seal
3. CDI needs to be replaced
Thanks for the help
Old May 29, 2017 | 03:27 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
IMO: Clean the carb good (removing both jets/float needle/etc) and see how it goes.
Then I'd do a compression test.
Make sure you use the cork gasket from the cover on the pull start.
The CDI's don't go out on these often.
Old May 29, 2017 | 04:08 PM
rowdog_14's Avatar
Cool on the CDI! I has a very faint spark but I could not remember if the spark should be more prominent since I have not trouble shooted a spark issue in a longggg time.
I have removed all the needles and floats and cleaning a little more. All still seems good but it does not hurt.
Going to get a compression tester now and will see what it return hopefully good compression.
Thanks
Old May 29, 2017 | 05:47 PM
rowdog_14's Avatar
So I just check the compression and it came to a big 0 . I tested the compression tester on my compressor and it matched the pressure in my compressor so, looks like I am going to be needing a new piston and rings or the crank seal I have read about that sucks. It was running so good I thought.
Would not having the carb and the side cover off cause any loss in pressure and not give a proper reading?
Also I am able to spin the gear with my fingers easily where the side cover is at. Would this be a good indication of lack of pressure?
Old May 29, 2017 | 09:14 PM
rowdog_14's Avatar
Ok I think I found out why I have 0 compression. The top gasket on the head is leaking. If you turn the gear on the compression stroke you can hear and feel air escaping from the head on the left side of the engine. Plus there is a little bit of oil at the bottom of the head. This should be an easy fix.
Old May 30, 2017 | 11:10 AM
DirtDevil101's Avatar
Are the 4 head bolts torqued properly...75 - 100 in/lb if I recall (6-8 ft/lb)???
Old May 30, 2017 | 12:39 PM
rowdog_14's Avatar
I did not even check. I will check when I get home
Old May 30, 2017 | 01:52 PM
let us know...
Old May 30, 2017 | 05:44 PM
rowdog_14's Avatar
Originally Posted by DirtDevil101
let us know...
Yep all bolts loose. I bet when I got it the gasket was already blown since the bolts were loose. Plus the gasket had a good deal of black soot where the issue was at. This did not fix it because of the damage on the gasket. Thanks for the suggestion
Old May 31, 2017 | 08:48 AM
LT80's Avatar
LT80 Expert
Guess that explains that eh..
