Eiger 400 Diff oil capacity?
Old Aug 21, 2017 | 09:49 AM
Ftrshooter's Avatar
Default Eiger 400 Diff oil capacity?
Most of the Forms I have read says to fill the front and rear diff's on the Eiger until the oil runs out of the filler hole , the Manual states 300 Ml in the front and 350ml in the rear wich is not much oil , so whats the correct amount to put in the diff's ?
Old Aug 22, 2017 | 02:05 AM
No you don't fill to the filler hole. Front and back have level plugs (below the filler plugs, 10mm spanner fitting.) You take them out, and if oil runs out, you have more than enough oil in. They air lock so slacken the filler plug too, and top up if oil doesn't run out.
Old Feb 24, 2018 | 02:42 PM
sarge11b's Avatar
acording to AMSOIL the capacity is as follows
LT-A400F Eiger 4X4 Auto
Engine Oil 3.28qts
Diff oil Front Drive .32qts
Diff oil Rear Drive .37qts
Fuel 3.96 Gallons
