Lt80 rear clutch
Old Jan 13, 2018 | 09:23 PM
Ta2tearz's Avatar
Default Lt80 rear clutch
Does anyone know if an 09 ltz90 rear clutch will fit an 03 lt80? I found one on ebay for $36 amd was trying to find out if it is same as the lt80. The pic looks like its the same clutch...
Old Jan 14, 2018 | 01:28 AM
LT80's Avatar
LT80 Expert
NO! It won't.
Old Jan 14, 2018 | 09:14 AM
Ta2tearz's Avatar
Originally Posted by LT80
NO! It won't.
can i use the small springs feom it to replace the lt80 springs? Thats really rhe only parts i need from it
Old Jan 14, 2018 | 09:38 AM
LT80's Avatar
LT80 Expert
I'd say no. They will not be the correct length.
Any reason you don't want to use LT80 springs?
Old Jan 14, 2018 | 09:40 AM
Ta2tearz's Avatar
i can't find springs for the lt80 unless i buy a complete clutch. OEM clutch is $100. Just trying to save $ if i can.
Old Jan 14, 2018 | 09:41 AM
LT80's Avatar
LT80 Expert
What's wrong with the ones you have?
Ta2tearz's Avatar
if you have some, or know where i can get them please let me know, ive literally been looking for 2 months.
Old Jan 14, 2018 | 09:44 AM
Ta2tearz's Avatar
they are shot....no tension left in them. Clutch opens up way too soon and bogs the bike down.
i replaced front clutch with OEM one. Replaced belt also.
Old Jan 14, 2018 | 10:25 AM
Ta2tearz's Avatar
thats the way my local powersports shop explained it to me. Ive already replaced complete top end, new air filter nrw carb new crank seals new chain installed fuel line shut off deletes oil injection system new plug new front clutch new belt....pretty much eliminated all other possible scenarios...things a dog off the line i mean a DOG...I was told clutch was engaging at too low of RPM causing the lack of power.
Old Jan 14, 2018 | 10:43 AM
Lt Granddad's Avatar
Did you ever address the roller issue from the other post using the Dr pulley sliders. They are almost twice the weight of the factory rollers unless that was random pic to show what was used.
