2003 Suzuki LTZ 400
Old Apr 24, 2018 | 09:50 PM
sarahandoakley's Avatar
Sarahandoakley
Default 2003 Suzuki LTZ 400
We can pull start the bike and it will run fine but if we try to electric start it the starter relay just clicks. We replaced the battery and relay. Any advice?
Old Apr 25, 2018 | 08:16 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check and make sure the ground wires are clean and tight.
Old Apr 26, 2018 | 02:31 AM
9 times out of 10 the fault is the starter, why people don't check the system before buying new parts is beyond me. First charge the battery, in case it is just low. Then get a test lamp and connect one side to battery negative, t'other to lead that goes from solenoid to starter, switch on, press start button, if the lamp lights nice and bright, but starter doesn't turn, you have a faulty starter. Usually just brushes need changing, but it is a "metal puzzle" getting it out on an Eiger, you can do it with carb in place, just.
quad riders
Dec 19, 2010 04:11 PM
golfpimp84
Sep 13, 2008 09:29 PM
RaptorOwner
Jul 1, 2006 03:23 PM
