Crank case
Old Apr 13, 2020 | 09:40 PM
JJh's Avatar
JJh
Default Crank case
Hey guys, I'm new to the thread. I have 2001 lt80 and I'm wanting to replace crank bearings and rod. Having trouble splitting the case. Any help would be great. Thanks in advance.
I also purchased the wiseco 100cc big bore kit with top end. Do I need to change anything with carb when running that? Also I removed injection pump so what mix is best to run with big bore kit? What type of 2 stroke oil is best. Thanks again
Old Apr 18, 2020 | 08:53 AM
LT80's Avatar
LT80 Expert
I don't replace the rods. I get a new crank.
No tuning is ness.
FYI: That big bore as it's not a big bore it's a china cylinder bored to the max and a Wiseco piston. It's 89.1cc's
I'm of the opinion that you are one of the many that has been duped by AZ Quads. Liars is the nicest thing I can say about them. Everyone thinks it's a Wiseco kit.
IMO, I'd send it back because it's "not as advertised". Then get your OEM cylinder bored to the next size Suzuki piston.
32:1 with quality synthetic oil.
Splitting the cases:: Have you done this before? Please explain what you have done so far and I'll help get them apart.
You can call me. Number in signature.
99veesixxer
8
Jan 2, 2013 06:37 AM
1988fast250x
May 3, 2007 08:05 PM
2strokesceamer
Oct 4, 2005 10:29 PM
bikepoordad
Feb 16, 2005 12:27 AM
holeshot77
Feb 14, 2003 09:41 AM
