Still no rear brakes on LT500
I posted about 3 weeks ago about my lack of rear brakes on my 1987 LT500. I took off the caliper and bought a piston kit for it from YSA for $28. This kit comes with new piston and seals. While I was at it I upgraded the line to a stainless steel braided line ($35). I also bought the special crush washers and discarded the old ones.
I assembled it last night and bled it. Everything seemed fine with a nice hard pedal. This morning before I hopped in my sedan I gave the pedal a puch. Mushy! I gather I need to rebuild the master cylinder. Anyone had any luck doing this? Pennzilla? I will order the parts today.
REPLACE THE SEALS ON THE SHAFT OF THE SLIDE IN THE MASTER CYLINDER. WITH OUT LOOKING I BELIEVE THERE ARE 2 OF THEM. WHEN I TEAR THEM APART I REPLACE EVERYTHING INSIDE BECAUSE IT IS RELATIVELY CHEAP. YOU MAY ALSO WANT TO REPLACE THE RUBBER DOBBER ON THE LID OF THE MASTER CYLINDER COVER. IF YOU TECH INFO HIT ON AN E-MAIL AND I COULD FAX OR E-MAIL YOU A CUT AWAY OF THE ASSEMBLY. ALSO BE SURE YOU DIDN'T SCRAPE UP THE SEALS IN THE CALIPER I HAVE RUINED ONE OR TWO TRYING TO GET THE PISTON IN. LET ME KNOW.
i had the same thing happen to my 500 just last week. I bled the brakes and they are crap still. think that mine is the master cylinder too.
What company makes the rebuilt kit and about how much are they?
One last question. Do you have to push the oil seal on the gear shift shaft from the inside?
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
