HSD A-Arms, Works front and rear shocks?????
Old May 12, 2001 | 11:56 PM
LBZfreestyler's Avatar
anyone had any good/bad experience with the hsd arms. also, opinions on works dual rate with rezzies with threaded preload??? and is the ultracross rear shock really worth 100 more bucks then the quadstar?? please give me a little info before i spend the money . thanks a lot
Old May 14, 2001 | 12:57 AM
PENNZILLA's Avatar
WELL I NEVER TRIED THOSE ARMS I USE LONE STARS, AS LONG AS THEY ARE MADE OF 4130 CHROMOLY THEY SHOULD TREAT YOU RIGHT. AS FOR WORKS THAT IS WHAT I USE ON MY WOODS ZILLA. I HAVE CHROMED DUAL RATE WITH REZZYS ON THE FRONT. AS FOR THE REAR I HIGHLY RECOMMEND SENDING YOUR SHOCK TO WORKS AND HAVE THEM REVALVE IT TO YOUR WIEGHT AND RIDING STYLE. IT WILL WILL RUN YOU ABOUT 200 BUCKS AND I BET YOU CAN'T TELL A DIFFERENCE BETWEEN IT AND THE ULTRACROSS. I HAVE ONE OF EACH AND BOTH ARE ABOUT THE SAME. I RUN THE PEP ZERO PRELOAD ON MY DUNE ZILLA AND WITH THE EXTENED ARMS I GET 14 INCHES OF TRAVEL ALL THE WAY AROUND. BUT THIS SETUP IS TO WIDE FOR THE WOODS.
txkevin
Sep 21, 2015 02:02 PM
bucklove007
Jun 8, 2015 07:28 PM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
250rCanCan
Sep 20, 1999 07:48 PM
