leaking water pump
Old May 13, 2001 | 02:01 PM
LT250RJ's Avatar
Well, I noticed I had the all too common coolant running out the weep hole on my 88 LT250R so I went and got a new mechanical seal. Put the new seal in and put it all together and filled the radiator. When I went in the garage the next morning sure enough there was antifreeze on the floor! So, the seals are new, and the case is not cracked or anything, so does anyone have any ideas on why this thing is still leaking?
Old May 14, 2001 | 10:14 AM
donpeter's Avatar
If is leaking while it is not running, it probably just a loose clamp, or overfmow leaking down a hose onto the frame and then on the floor. The Suzuki manual says you are suppossed to put 2 ounces of powdered radiator sealer in the radiator every time you change or flush the coolant, but that only helps pumps that wheep when running.
Old May 18, 2001 | 08:00 AM
shuttlemech's Avatar
Your problem is the seal under the bolt head that holds your impeller on. They are aboutg 4 dollars at the suzuki shop. Change it and your problems should be solved.
Old May 19, 2001 | 03:48 PM
LT250RJ's Avatar
Thanks, that seal very well could be it. I've changed everything but that. I also tried the powedered water pump sealant but to no avail. I'll go out to get that washer/seal. Just hope the dealer has one. Thanks guys.
Dave
2quiker
Mar 22, 2022 08:36 PM
Minimod
Sep 10, 2015 08:03 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
quickwhips
Sep 2, 2015 06:53 AM
