won't idle
Old May 15, 2001 | 10:58 PM
bdscram1's Avatar
first problem i have had . I have a 86 lt250r it ran great and idled great now it wont idle and seems to load up real bad. I have a fmf pipe and uni clamp on filter. what should i have for jetting? I know it has a 260 main in it I dont know about the rest. the book shows 210 main is stock. it revs on top fine once it cleans out.
thanks
loren
Old May 15, 2001 | 11:30 PM
ProtegeDK's Avatar
You need to change jetting with that pipe and filter. The main should be OK , try lowering the jet needle by raising the E-clip to the second groove from the top. Stock it comes in the middle groove.
Old May 15, 2001 | 11:46 PM
NewDSLover's Avatar
Change your plug also. Like Pro~ said, raise your clip will lean it out alitle on bottom end. Most times it's the weather/temp/season changes that causes the problems your having.
Do these things:
Clean your filter & reoil
Change your plug
Clean your carb
Raise your needle after doing the above steps.
Good Luck
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
