carb jetting
Old May 16, 2001 | 05:35 PM
suzukiboom's Avatar
i have a aftermarket pipe on my 89 lt250r and a rad valve,how should i rejet the carb?it
bogs alot in the lower rpms
Old May 17, 2001 | 12:48 AM
ProtegeDK's Avatar
You need to rejet. Make sure your filter is clean and buy some plugs. Start with the main.
You have stock carb?
It should be around #260 for that set up, and once that acomplished work with your jet needle.
From experience, 1/4 to 3/4 throttle is always rich on these bikes. You need to lower the needle by raising the E-clip to the 2nd groove from the top.
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
