Does Duncan make a pipe for the 86 LT250R?
Old May 25, 2001 | 02:07 PM
GaryManilow's Avatar
Does Dunacn make a pipe for the 1986 LT250R? Thank you.
Old May 26, 2001 | 01:19 PM
URnotRoscoe's Avatar
Nope, I went in and talked to them and they told me that they don't because there isn't enough of them around to put the money into design and testing.
Old May 26, 2001 | 03:43 PM
OK thanks man, I guess that narrows down my choices ..Whats the best pipe you've found?
Old May 28, 2001 | 04:22 PM
I've always leaned towards FMF for my 2 strokes. I noticed a big difference on my 85 but an even bigger difference on an 86, I think they work better with the bigger carb that came on the 86. Keep in mind the biggest factor for selecting a pipe is how and where you will ride. I ride almost exclusively at Glamis so top end is a big concern. The bad part about the FMF for the Quadracer is the way it mounts. It always leaks at the intermediate pipe. I am seriously considering welding it because it is always coming loose due to the fact that the silencer only has one mounting hole. Also if you put the flange on the engine wrong it will stress the rubber mount at the top of the pipe and it will seperate.
Old May 30, 2001 | 11:23 AM
Thanks for the tips Roscoe.
JohnnySplat
Aug 6, 2015 12:07 PM
zach1106
Jul 31, 2015 01:55 AM
Reactant
Jul 27, 2015 07:45 PM
traumajunkie
Jul 23, 2015 02:10 AM
cSchwartz
Jul 12, 2015 07:42 PM
