engine swap
Old Jul 13, 2001 | 11:49 AM
dillas23's Avatar
I am in the process of putting a LT185 motor into a LT125 frame. I have been told that they will interchange without any modifications. My questions are:
Will the LT 125 carb work?
Will the LT125 coil and CDI work?
And do I need to keep the LT125 sprockets and chain?
This quad is only being used for light utility work and hunting, as I am going to put front and rear racks on it. Any help would be greatly appreciated.
Lee Crawley
Old Jul 18, 2001 | 10:41 PM
bermbanger's Avatar
Ok i'm gonna tell u what i know
My uncle did this and the engines bolted right up except a few didn't so they just didn't use them. Its still fine then. I would use the 185 carb since thats what its jetted for. since they are both Zuki's the 125 coil and cdi should work. I would use the 1855 front sprocket and 125 back sprocket. Hope this helps.
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
