MELTED QUADRACER PISTON
Old Jul 27, 2001 | 01:17 AM
ProtegeDK's Avatar
Just need some info on what went wrong.
Went to Silver Lake this past weekend, and was drag racing and hill climbing for 2 days. On the third day, I was crusing around and as i down the last hill, my suzuki died.
Found out i melted the piston on the exhaust side above the first ring.
I want to know what you guys think went wrong.
Was running a tad rich.(i kept an eye on the plug)
Custom air box(no way sand could get in)
No leaks
Could float height been a factor? If i would suck all the gas out of the bowl before it could refill.
Or was the main just too lean? I have a 195 main in it. (does Kehin have any bigger than a 200)?
When I would drag race it sometimes would cut out around 5th gear pinned, then i would slow down.
Thanks alot guys. Derek
Old Jul 27, 2001 | 08:25 PM
bermbanger's Avatar
Sounds like the main might have been lean.
Old Jul 31, 2001 | 06:34 PM
2strokeDiehard's Avatar
Sounds like crank seals, It will seem rich at idle but once under power it sucks in air around the seals making it lean. Going down the hill if you was off the throttle it creates a high vacuum condition in the base causing it to suck air by the seals. This is a very common problem.
Old Jul 31, 2001 | 06:52 PM
SuperJetter's Avatar
In addition to the post above about crank seals, replace the o-rings on the exhaust valve. Don't check them, just replace them. Had the same problem. No more. After 10 years the rubber starts to get weak.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Halffast17
Sep 11, 2015 02:30 PM
