AAAAhhhhhhh!!!!!!! LOST THE KEY
Old Sep 26, 2001 | 12:29 AM
jfboy's Avatar
Ok I lost the key to my dam LT250 I know I'm a dumbass but somebody wants to buy it and I cant even let him test ride it....... Anyway how to make it run without focking up the switch???.... Can I play with the wires coming out of the switch ?????
Help me out please I need that money to soup up my 400ex(dont take it personal)
Thanks in advance
Old Sep 26, 2001 | 12:55 AM
AussieZilla's Avatar
well from my experience of wiring up a kill switch on a banshee and my LT, there should be two wires coming out of the switch. if so, then you need to connect these wires together to complete the circuit. just strip back a little of the insulation on each wire (dont break the wire!) and tie them together with another peice of electrical wire. either that or you could put another 'on/off' switch in between the wires. On a kill switch, the engine fires when the circuit is broken. with the key switches i think it fires when the ciruit is complete, ie joining those wires together. hope that helps [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 26, 2001 | 01:06 AM
waynaferd's Avatar
Yeah, do what Aussiezilla said. When I got my 500 it didn't even have the key switch on it, just the kill switch on the handle bars. I plan to get one though....
Old Sep 26, 2001 | 02:05 AM
madweazl's Avatar
I dont know if its the same on the LT's but the key switch on the Mojaves will work with it being disconnected. I think its called a grounded switch. Anyways, try disconnecting it and see what happens, it works on the Mojaves and I bet the LT is probably the same. Good luck, Aaron.
Old Sep 26, 2001 | 02:33 AM
Guido39's Avatar
It's the same way with LT's. If the ground is not grounded, then it will run. So, just cut the ground (black wire).
Old Sep 27, 2001 | 05:01 AM
jfboy's Avatar
I'll try that.... hope ir works It hasent run in 3 months........
lonerider856
Oct 13, 2023 03:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
