86 lt250r
Old Nov 11, 2001 | 02:06 AM
Mojave87's Avatar
Are the 86s realy that bad i have heard some good things and some bad things. My friend knows someone who has a 86 that needs some work which i have no problem with, it will give me a winter project but i dont want to buy this thing then find out its a pile of you know what. he wants like 200 or 300 for it, i didnt think it sounded that bad for it, what do you think?
Thanks
Old Nov 11, 2001 | 11:08 PM
ineeedabudlight's Avatar
Check the frame for cracks by the front shocks top mounts and around the footpegs. also check out the swingarm for cracks. I have an `86 Racer and mine has been fixed buy the shock mounts and the swingarm by the pinch bolts has been welded. I just bought another frame this weekend and am going to do some gusseting then sandblast and probably powdercoat it. then do a weekend swapover from the original. The 86/86 doesn't have the powervalve and the reeds are in the cylender bace, but, are very good quads and very reliable. I have alot of mods done to mine and it ripps. For the price your freind is asking you can't go wrong.
Danno
Old Nov 12, 2001 | 02:46 PM
1986SuZuKiQuAdRaCeR's Avatar
holy crap! 300-200 bucks!!! I bought mine for 700 with most of the engine gone and I get offers for it from 800-900!! it must be a piece...
I like mine... but it don't run...
Old Nov 12, 2001 | 06:35 PM
Mojave87's Avatar
yeah the frame has been cracked in one place... vy the foot peg but it has been welded... how much would a new frame run for?
Old Nov 12, 2001 | 07:55 PM
You really don't need a new frame, as that won't fix the problem. You can have the frame welded and gusseted to strengthen it. I bought another used frame this past weekend so I could keep riding mine while I have the other one worked over and then maybe powdercoated. After I got the used one home and did a very colse comparison I found it to be in worse shape than I thought. I'm not shure if I will use it or not. I will have it sand blasted and realy check it over before I make my final decision. If you do go with another frame you really need to look it over. I found some of the mounts either cut off or stripped and bolts welded in. I'm shure a new one frome Suzuki would be very expensive, Then it will still have the same week areas.
Danno
Old Nov 12, 2001 | 09:38 PM
I would make a new frame...
and I think I will...
did someone say ALUMINUM?
Old Nov 13, 2001 | 06:51 PM
Mojave87's Avatar
to build your own aluminum frame it would cost a ton of money... i gotta find out more about this quad and take a look at it
Old Nov 13, 2001 | 08:14 PM
yeah, it would be expensive, unless you had access to materials for discount or free from work like I find myself sometimes. And as long as you had a TIG or ARC welder, plenty free time, knowledge and experience...
it's fun and gets ya dang fast real quick!
Old Nov 17, 2001 | 02:13 PM
bdscram1's Avatar
suz quit making that fram 5 years ago I already cheked. Im buing a pipe bender from northern tool and as a winter project try and I mean try to build a frame. pipe bender is 100.00 bucks some pipe going to go with square tube for added strengh. mabe 200.00 in steel
Old Nov 17, 2001 | 10:25 PM
According to Bike Bandit you can still get a frame for the 85/86 quadracers. A frame for a LT250R(F/G) will cost $816.05. I'm glad I found a straight used one for $80 and it had a straight steering shaft in it.
Danno
