lights out
Old Dec 19, 2001 | 11:31 PM
dynamoD's Avatar
riding along this evening around dusk,turned on the lights and the engine died.found the 20 amp main fuse blown,installed the spare and rode home in the dark.When I got to the carport tried turning on the lights again, same results.I have a short in the light circuit,but where,no signs of naked wires are visible.Anyone had this happen before? 99 Quadrunner 250 4x4
Old Dec 23, 2001 | 09:05 AM
Kawi250's Avatar
Try checking the actual bulb. Just a guess.?.?
Old Dec 24, 2001 | 12:03 AM
dynamoD's Avatar
Well I checked it this morning,pulled all connectors apart at the lighting circuits,checked for shorts to ground ok checked for shorts between each wire ok.The connectors on the taillight circuit were full of dirt and water so I cleaned them out with some pcb cleaner,pulled the fuse,checked amp draw through fuse holder as I reconnected each connector 1 by 1.Only 4.5 amps with all lights on,so reinstalled the fuse,everthing ok.I guess the mud in the connectors was the culprit.v
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
