what restrictions are in an stock LT80 exhaust system???
Old Feb 5, 2002 | 09:50 AM
DSAPP's Avatar
and how do you remove them?
Old Feb 5, 2002 | 10:11 AM
LT80's Avatar
LT80 Expert
there is 1 that limits the carb slide,remove the carb slide then remove the brass ring inside.
they say there is one where the pipe connects to the cylinder,remove the pipe and pry that out,,should get ya going a lil better [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 5, 2002 | 11:28 AM
DSAPP's Avatar
what about the spark arrester?
what type does it have?
is there an easy way to remove it.... or at least just service it?
Old Feb 5, 2002 | 01:02 PM
LT80's Avatar
LT80 Expert
In 9 years of LT-80's I've not heard of any servicable spark arrestor. I figured the baffles in the pipe performed the spark arrest duties.
Old Feb 5, 2002 | 03:51 PM
DSAPP's Avatar
thanks for the info guys.... need to add some inexpensive OOOMPH to my sons LT-80
now... if I do exhaust mods like removing these restrictions... I should probably up-size the main jet, huh?
Old Feb 5, 2002 | 05:43 PM
LT80's Avatar
LT80 Expert
I guess that i would recommend a plug check ,like any mod.The stock jet is enormous.On my ported cylinders I run a 77.5/37.5 and I would go to using premix gas/oil.Every now and again the oil injection pump quits [img]i/expressions/face-icon-small-smile.gif[/img] I tried your web addy thats in your profile.It didn't work.I have thoughts on your LT-80,email me plz [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 2, 2004 | 05:24 AM
lovbyts's Avatar
Default what restrictions are in an stock LT80 exhaust system???
On topic
When doing pre mix do you need a block off plate for the LT80 or just disconect? Where do we get the plates if needed? Thanks LT80
PS. Is it really worth putting an aftermarket pipe on an LT80 if you are not racing but just want moderate gains?
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
