Anybody know where I can get a rebuilt motor?
Old Mar 7, 2002 | 09:18 PM
RedRooster's Avatar
I'm rebuilding my 86' Quadracer from the frame on up and I would like to trade my motor in on a good running one. My cases are trashed and my bearings and everything else seems to be going bad. I already called East Coast ATV and they don't have any 86' motors. Anybody know anywhere?
Old Mar 8, 2002 | 10:59 AM
Chapy's Avatar
Does it have to be an "86". Won't any other the other years work.
Old Mar 8, 2002 | 05:37 PM
RedRooster's Avatar
If it won't be hard to drop an 87+ motor in it I'll get one
Old Mar 9, 2002 | 01:17 AM
1986SuZuKiQuAdRaCeR's Avatar
I put an 89 RM250 engine in my 86 Quadracer... (I haven't run it yet) and I think it has the same mounting points as the 87+ Quadracers... I had to make and weld on the head mount, and the upside down Y-shaped crossmember that the exhaust goes through...
AND I don't have the benifets or strength of a real '87 quadracer...
So, I wouldn't completely reccomend it unless I was going to do lots of frame or suspension modifying, anyways...
Go with an 87+ frame and suspension if you're thinking of doing an 87 engine, unless of course you really don't care about your frame strength, suspension, stability and handling that much... [img]i/expressions/face-icon-small-smile.gif[/img] It would also require a bit less work to use the 87 frame... It would all be bolting, no torching/welding/chopping... Hope this helps...
Old Mar 9, 2002 | 07:30 PM
kciH's Avatar
If you check on Ebay, there are motors on there from guys who are parting out machines. I would try to get a running motor and rebuild the bottom end, or have it done at a very good local shop. Get you cylinder ported/bored by a good shop, bolt it together and go roost.
Old Mar 10, 2002 | 02:25 AM
Chapy's Avatar
Hey red rooster where is Rockwood? I'm from williamsport
Old Mar 11, 2002 | 09:05 PM
RedRooster's Avatar
Rockwood is southeast of Pittsburg. If you saw where flight 93 crashed on the news, I'm only about 10 miles from there.
fd24
Jan 16, 2019 08:59 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Sep 9, 2015 09:38 AM
chewy78
Sep 8, 2015 10:37 AM
