Clutch Problem
Old Mar 29, 2002 | 07:00 PM
braetz230's Avatar
Guys i need some help. I just put new fiber plates and discs in my 230-Qsport. I went out today to try it out and my clutch lever was very hard to pull in. Once you finally got it in the clutch woulld not catch or soething like that. It was like when you pulled in the clutch it would want to take off with you or something like that. I really need some help guys.
Billy
Old Mar 30, 2002 | 02:41 AM
MrSector9's Avatar
If the clutch is properly put together inside the case,then it definatly sounds like it is way out of adjustment on the engine side and also on the handle bar lever.You might also have to change the position of the clutch arm that is attached to the shaft that comes out of the engine clutch cover itself.
BJ White
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
