Extended A-arms good or bad?
Old Apr 3, 2002 | 05:55 PM
stockyM's Avatar
I looking to buy new A-arms (Strong Arm) and was going to get +1-+2. For my 250R. But i wanted to know the limitations or better yet the advantages and disadvantages. What do you have on your bike? Do you prefer it or would you have left it stock? Does it make trail riding more dificult?
Thanks for your time.
Old Apr 3, 2002 | 06:20 PM
dual-sporter's Avatar
it depends on your needs...
if you're racing MX or TT widening makes it more stable, able to corner harder same goes for dunes riding. for trail riding, it limits some of the trails you can go on... depending on how tight they are. if it's just for normal trailriding i'd say not to do it, at higher speeds it just puts the wheels out further to hook on a tree & send you spinning.
plus... you will need new shocks(or re-valved & re-sprung if you have aftermarket already), the new wider A-arms creates a lot mor leverage on the shocks.
i'm currently running magnum +2" A-arms on my '91 LT,(if i'd known about strongarm when i bought them, i'd have strongarm A-arms) i ride some dunes, do some local racing, and some trail riding. i have stock shocks on it right now(cranked preload and copression adjustments all the way up) and i bottom it occasionally, so i take it easy on the jumps until i can afford to get some shocks setup for it. trail riding i have found some bridges i can't cross and some trails i can't go on. but that's the price i pay... to (eventaully) be a little better on the track. i also matched the A-arms with a wider axle(i recommend lonestar or RPM)...together it is more stable all around.
Old Apr 3, 2002 | 09:35 PM
stockyM's Avatar
Thanx
Frisky2050
Apr 9, 2020 11:19 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
