Tire Problems
Make sure you use Slime and not fix-a-flat. Slime doesn't dry up. When changing tires, I will even take the Slime out of the old one and put it into the new one. Fix-a-flat is for emergency purposes only. Slime will rinse right off the rim with a little soap and water or you can just wipe it off with a rag. It does not stick like glue to the rim or tire.
I run Slime in every tire I have both front and rear. I've heard of people say it throws the tire out of balance but haven't experienced it myself.
4 or even 6 ply tires definitely help but won't eliminate the problem of thick thorns.
/NotuRaptor
/NotuRaptor
If you use SLIME in your tires just make sure you tell the mechanic (or whoever) is going to change your tires.I had one that they enver told me it was in there and there was ALOT at least a full bottle in each tire.Hit is with the bead breaker and it blew slime all over me and the shop :/
BJ White
BJ White
Wow, that's interesting GreatCanadian. If you want I'm sure I'll be able to send you some seedlings!!! hee hee We have lots of the buggers here and are a good 3 inches long. The buggers are tough enough to go through a tire no problem at all. Ripped a few good jackets on them too. I'm on a SAR team and we have to deal with them on pretty much every search we have in the woods. Be glad you don't have to deal with them.
#18
Sambo you put your nose up NukeZuke ***.That is up to you. You dont tell me sh-t.You worry about your Queen and your dollar.Your Queen will tell you what you can and what can't do.Your dollar is not worth sh-t here or where you live. NukeZuke you run your mouth about michigan untill you found out that I lived there and new more then you did. You don't even know how many countys you have in in the upper peninsula of michigan and you live there. You go for a ride and its what 2 miles maybe 3 LMFAO. Are you jealous that I can lick my nuts. You don't even have 2002 Eiger.
You got a 1982 Big Red. You are nothing but a wannabee. That is all you will ever be. Sorry it took so long to get back to you but I was on a little hunting trip 325 miles in 3 1/2 days. So dont talk sh-t to me with a 1982 Big Red NukeZuke
2002 Eiger
2001 KQ
2002 Eiger
2001 KQ
toonces
Oct 16, 2019 12:11 PM
