1991 LT250R internal engine disassembly
Old Apr 19, 2002 | 01:35 PM
Melonmasher's Avatar
I've got 91 lt250r does the Clymer 85-88 cover my motor exactly? I was given this 250. Don't know anything about it. The motor has sat for 6 months needing a new top end, but when I picked it up the bottom end was exposed, so I am taking it apart to clean it and put in new seals,bearings, whatever. what do I clean the gears,clutch,bearings, inside case with?(Gunked up) How do you get the clutch basket nut loosened. Is there a special tool to hold the basket or do you hold the drive sprocket to loosen the nut, is it reverse thread?
Old Apr 19, 2002 | 01:49 PM
ltracerx's Avatar
Buy the Clymer for the 92 LT250 and that will tell you everything. The Suzuki Manual is probably better, but they're usually overpriced. Check Ebay under "quadracer" "LT250" "LT250R" and manual in the search box, there is always something there.
Old Apr 19, 2002 | 02:14 PM
I've never seen one for a 92 where can I get one? All Ebay has is 85-88 for the moment.
Old Apr 19, 2002 | 02:22 PM
ltracerx's Avatar
Call your local dealers and ask if they have them/can get them. If Clymer doesn't make one, which I tought they did, you'll have to get the Factory manual.
Old Apr 19, 2002 | 02:51 PM
I got the basket off, I think my balancer is 180 deg off, quad vibrated too much when running. At TDC the gear marks are opposite each other at BDC they line up. When I searched they said 3 marks must line up at TDC. Wheres third mark? I have the motor right next too me, any help would be welcome.
Thanks[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 19, 2002 | 03:01 PM
ltracerx's Avatar
Read This thread.
Old Apr 19, 2002 | 03:20 PM
Thanks Itracerx, what about a cleaning agent that won't hurt the bearings, seals, etc..
Old Apr 19, 2002 | 03:30 PM
ltracerx's Avatar
I don't know what to use for cleaning stuff, but I wouldn't use anything thats under your kitchen sink.
Old Apr 19, 2002 | 06:18 PM
Can I use carb cleaner, will this hurt the seals or should I use gas and a soft brush?
Old Apr 19, 2002 | 06:45 PM
ltracerx's Avatar
I dunno about carb. cleaner. The gas idea should be fine, just don't rip your seals with that wire brush.
slowgsxr97
Mar 18, 2022 03:40 AM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
Gnuters
Jul 19, 2015 10:03 AM
Unzzy66
Jul 11, 2015 10:01 PM
