Lt500 front shocks rebuildable ??
The front shocks on the 500r are NOT rebuildable...however, I took mine apart, cleaned them out and added some oil and away I went with a good pair of shocks. Over the years the oil will make it past the seals and dry up!
87 zilla FMF pipe, K&N filter
87 quadsport
87 quadsport
the alloy body LT 500 shcoks can be disassembled and serviced etc. Suzuki does not (?) carry service parts such as seal head and damper piston parts. Any good shock shop should be able to service them for you, seals will be a case of matching something up or machining the seal heads to take an alternative seal. Talk to Wayne at PEP, he knows his suzuki's.
Kiwi
Kiwi
#15
Take the two lock nuts that hold the spring up, then unscrew the top plate off. It's got two little holes on the top. Use a pipe wrench, visegrips or you can use the disk wrench off of a makita disk grinder in the two hole to unscrew. You can buy some BelRay fork oil to refill. I recommend 5W. Hope this helps.
87 zilla FMF K&N
87 quadsport
87 zilla FMF K&N
87 quadsport
#16
Actually the front shocks on the LT are rebuildable, in fact they are the only stock units on quads that are rebuildable. These are Showa shocks, very nice equipment considering the age of the Zilla. I had mine revalved for my weight and style of riding by a local mechanic, it is also possible to attach canisters to these particular shocks. I have not done that, but it was explained to me that it is not that difficult of a task if you know what you are doing. If you have no one local, I would contact PEP and see what they can do for you.
#17
Hey zukiboy and ltracerx
Did you guys get the pix ????
Everyone else ...Thanx for the replys !!! I have a local guy who can rebuild my shocks. Now I need a full set of plastic too...I hear the brand new maier stuff looks real good !! My pipe is almost ready for chrome... this thing is huge !!! 2into1 !!!! won't be long now.
keep your eyes open for another LT500 roller My buddy wants to build another one !!!
