Gray Oil
Old May 13, 2002 | 10:02 AM
Steele's Avatar
Guys, what do you think.....I blew the piston so i took the jug off etc to take the cylinder in to be honed and bored again .30 over. Got it back, put everything back together , changed the oil and it ran super. After about 6 hard hours on it i changed the oil again and it looked like gray paint. I checked the antifreeze and it appeared full, we did ride thru some deep water crossings and thought maybe thats how (not sure how). Then i thought that maybe when i took the jug off that some of it went down into the bottom end that didnt come out when i changed the oil the first time.
What do you think?
Old May 13, 2002 | 10:38 AM
BadVinson's Avatar
I think I would go for the deep water idea. Check everything to see that it is sealed good.
Old May 13, 2002 | 12:27 PM
ltracerx's Avatar
<< . Got it back, put everything back together , changed the oil and it ran super. After about 6 hard hours on it >>
Did you forget to break it in? I know that couldn't cause your oil problems because this is probably a 2 stroke, but I was just wondering.
Old May 13, 2002 | 01:02 PM
Steele's Avatar
Yes it was broke in properly. 3 heat cycles, rode easy for quite awhile after.
Old May 13, 2002 | 04:48 PM
jcv400ex's Avatar
You def. got water in there. that's why it's gray. Prob. sucked it either through the air filter, or cold water hitting a hot engine will cause an engine to &quot;draw&quot; the water in between gaskets.
Nothing too big, just change the oil...
Old May 13, 2002 | 04:55 PM
warrior007's Avatar
I do head gaskets on dodge neons in my spare time, I know once you get the water in the oil its sometimes terrible to get out.
If you got enough water in through a deep water crossing to turn the oil gray the bike would have died and sunk.
My feeling is the water pump or seal is shot.
Old May 13, 2002 | 06:08 PM
Steele's Avatar
THANKS GUYS!
awheelterd
Feb 2, 2021 06:18 PM
POO
May 6, 2003 06:31 PM
rhino99
KTM
Sep 21, 2001 11:56 PM
Zorro
Nov 8, 2000 02:47 AM
floodrunner
Dec 7, 1999 10:33 PM
