Eiger Valves Ticking
Old May 20, 2002 | 08:26 PM
eigerguy's Avatar
The valves on my 02 eiger 4x4 manuel have ticking sound after it is warmed up. The noise is only occurs when going up a hill or accelerating real hard. It doesn't seem to effect my power or be a major problem. Could the motor be out of time? If so, how do you fix it?
Old May 21, 2002 | 01:45 AM
BuggyBrian's Avatar
Sounds like it could be spark knock. Are you burning a high octane fuel?
Old May 21, 2002 | 07:44 AM
DeerChaser's Avatar
Mine ticks all the time when warm. I took it in at 10 hours, the dealer said they were fine. But you all know what kind of problems I have with this sorry dealer. I wish I could find a repair manual. Jerry
Old May 21, 2002 | 09:18 PM
eigerguy's Avatar
I have been using 89 octane gasoline. What is spark knock? What I'm hearing sounds like preignition.
Old May 21, 2002 | 10:58 PM
Wolley's Avatar
Just for grins pull your plug and see if there is a lot of carbon built up on it. Sounds like pre-ignition. Same as spark knock. Not good! I'm having a little trouble believing that the Eiger would need high octane fuel. 9:1 compression ratio should be able to run on 87 octane fine. I suppose it could be too far advanced but I wouldn't have a clue how to change it. It appears to be CDI ignition and I would think that there probably is a way to adjust it.
One other thing to look for. Check the plug number. It should have a CR7E. Mine came with a CR8E. Don't know which one is hotter. Too cold of a plug maybe? This would allow too much carbon build up resulting in pre-ignition.
Could be the valves but I doubt it. Have you done the 100 mile valve clearance check?
Old May 21, 2002 | 11:32 PM
BuggyBrian's Avatar
In the manual there are 3 plugs recommended. 7,8,9. I beleive the 7 is the hottest, but better check to be sure. First get a new plug or clean the old one real good. Take it out and run it hard for about 5 to 10 min. Shut it down right away... Do not let it idle. This will give you a plug reading at top end. Your leanest point. Plug should be light brown to white. If it's dark, you need a hotter plug or a smaller jet. Do not check the plug at idle or low rpms, because if it is clean there it will be real lean on top.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
