Z400 headlight problem
Old Jun 21, 2002 | 03:36 AM
thrshr's Avatar
here's an easy way to find out if it is a ground problem or not before you start taking the quad apart. just find out which wire is ground on the headlight and bypass the factory ground wire. if the lights stays bright then go ahead and start taking the quad apart, if it doesn't then you should look elsewhere.
just to make myself clear, what i meant by bypassing was to get yourself a wire and directly ground the lights either to the frame, motor, or better yet the battery.
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
Derek Allen
Jul 22, 2015 09:25 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
