MAKE YOUR OWN OZARK SPEEDOMETER
Old Jun 24, 2002 | 12:26 AM
LVOZARK's Avatar
since the ozark atv from suzuki comes without a speedometer, i found that a bicycle speedometer called the sigma 800 works well and is easy to install. it costs about 25 bucks. let me know if anyone needs more info.
Old Jun 24, 2002 | 11:59 AM
CoryB's Avatar
Where did you mount the pickup and magnet? I'm interested in any info you can send.
Old Jun 25, 2002 | 12:10 AM
LVOZARK's Avatar
go to radio shack and get some flat magnets
mounted sensor on the round plate that protects the brakes
use cold steel to stick magnet to inside of wheel rim
before you stick the magnet, make sure it will come no more than 5mm from sensor when the wheel spins
i drilled a couple of small holes in the plate and mounted the sensor with 2 small screws. also if you might need more than one magnet on top of the other to get the gap to 5mm or less
so far it has been very reliable, good luck
Old Sep 22, 2002 | 04:56 PM
SuzukiQuadrunner160F's Avatar
this may be a little out dated but can you tell me where u got the speedometer. Also does going throught mud etc mess it up.
user493
Aug 13, 2015 12:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Jul 31, 2015 09:27 AM
Nazz26
Jul 30, 2015 11:51 AM
traumajunkie
Jul 5, 2015 03:03 PM
