%^&$%^ shift out of neutral!!
Old Jul 8, 2002 | 08:46 PM
Corpsie's Avatar
(I did a search and didn't find anything, so pardon if this is a repeat)
Has anyone had a problem with their Z400 not shifting into first from neutral when it is warmed up? My buddy and I both have Z400's (mine is a few weeks older in use) and we both get stuck in neutral. It feels like the shift lever isn't catching-on/moving anything.
What's the dealio?
Old Jul 8, 2002 | 08:47 PM
Sandgod's Avatar
Rock the quad back and forth.
Old Jul 8, 2002 | 08:59 PM
Corpsie's Avatar
I'm really new to this stuff, is it normal for that to happen?
My friends' 400EX, Raptor and Banshee don't do it. *sigh*
Old Jul 8, 2002 | 09:51 PM
vooduuchild's Avatar
nothin to worry 'bout. Rock it back and forth. It also will happen when it's off more often than when it's on. Nothin to worry about.
Old Jul 8, 2002 | 10:00 PM
GTV's Avatar
GTV
Every manual transmision made can do this under the right circumstances. Put light pressure on the shifter at an "idle" and slightly let out on the clutch, presto, your in gear! Same with reverse.
Almost every vehicle I have owned has been with a manual trans, they all have their own slight differances, you just have to adjust to their likeing.
Good luck,
Later...
Old Jul 8, 2002 | 11:13 PM
JRide's Avatar
Corpsie its nothing to worry about everyone of my bikes/quads have done this. I don't really know why they do this but if you let the clutch out and a little bit and tap the shifter it should go right in just don't let it out to far or you'll grind the gears. Rocking the quad back and forth works as well. Don't worry your Z doesn't have a problem. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 8, 2002 | 11:37 PM
Corpsie's Avatar
thanks. I'll try those tips next time I go out.
*sigh of relief*
95wolv
Sep 27, 2024 12:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
