Z 400 Low End Power
yeah the low end isnt that great but since i put the hmf pipe and filter kit on it rocks. i can pull about every hill in the dunes in 3rd gear or 4th ( used to have to downshift to 2nd on most big ones). you might not be jetted right. i put in a 152.5 and im still lean although not by too much i think. dynojet also has a kit out since the needle is not adjustable. they should of used a differnt carb on it, like the one on the EX. its also easier if you ride kinda like a 2 stroke, keep it reved up. also i think its geared a tad low, but the pipe and filter on now it doesnt seem that way.
#19
There is an air jet that looks like a main jet by the main jet, the pilot is also right by the main but it is inside of a round inset that is molded into the carb. The head of it has a straight slot for a straight slot screwdriver, it is smaller round but longer and when you take it out it should have 22.5 on it. I hope I described it where you could understand.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
