400z vs quadzilla
Old Sep 1, 2002 | 02:51 PM
spongebobsquarepants's Avatar
ive never really saw any 400z's run stock to stock is it as fast as the quadzilla?
Old Sep 1, 2002 | 03:04 PM
bandit390's Avatar
no! lol
Old Sep 1, 2002 | 03:08 PM
i thought about buying one to play around with, i have a fast banshee to drag with... i know a stock ds650 will run with a zilla or will be real close to it.. so that kinda rules out the 400z
Old Sep 1, 2002 | 06:14 PM
dezertfreak's Avatar
My brother has a mod 500 and though my z may not be all around as fast as it, it pulls just as hard and has just as much top end. the 500 has loads more mid and low.
Old Sep 1, 2002 | 07:27 PM
yamblaster98's Avatar
dezertfreak you are full of BS. the Zilla had the highest top end on any quad ever produced. No way is your Z400 going to hang with it since it 1 has mods and 2 the Z cant even hang or beat machines like the raptor.
Old Sep 1, 2002 | 08:19 PM
ZILLAMANINALA's Avatar
Sorry guys a stock ds 650 will not stay close to a zilla and neither will any other stock machine ever produced. And before it starts i know you could modify anything to keep up with the zilla but stock for stock nothing else even compares.
Old Sep 1, 2002 | 08:54 PM
Correct me if im wrong but when get on a 500 doesnt it just spin whereas a z hooks up a little better. now going off that i will say my z will pull just as hard. if you put the two on asphalt where traction is at its highest the 500 will kill it. if you put the two on ice (no studs in the tires) where traction is at its lowest the z will win. the 500 hits hard but losses traction, the z rolls into the power keeping traction.
Old Sep 1, 2002 | 11:08 PM
truckracer's Avatar
<< Correct me if im wrong but when get on a 500 doesnt it just spin whereas a z hooks up a little better. now going off that i will say my z will pull just as hard. if you put the two on asphalt where traction is at its highest the 500 will kill it. if you put the two on ice (no studs in the tires) where traction is at its lowest the z will win. the 500 hits hard but losses traction, the z rolls into the power keeping traction. >>
Ok - your wrong - the only time, place, or direction the Z400 has a chance is in reverse! I am not knocking the Z, it's just not a Zilla replacement no matter how bad the new owners of the fine Z400 want it to be.
Old Sep 1, 2002 | 11:54 PM
RaptorRider660R's Avatar
It will hang just till the point the zilla gets traction then kiss the z400 goodbye it will be long gone before he shifts out of 3rd gear, and by the way a stock DS 650 will not hang with a Quadzilla either, it will last a little longer than the Z400 but by the end of third start of forth the Zilla just pulls away!
Nocando
Old Sep 2, 2002 | 01:02 AM
im just going by one of the guys on the ds forum.. when i had t-5 pipes on my banshee and basic mods like timing and k&amp;n... dsmikes stock ds would run side by side with me.... id love to see some quadzilla guys come down and run at the local strip in okla..
